Why can't I lock up on the dyno?
Just a question I've scratching my head for a while and never got a straight answer. Tuner have told me that some cars do that. But I'm curious if I can fix this problem. Since my tranny won't lock up on the dyno would that affect the tuning on the road or at the track? It does fine on the road and the track. Of course if it does I want to fix it and maximize the potential of my car if I can fix it. I'm going to put it on the dyno again after the upgrade of my H/c swap. Anyone know what causes this?
There are other ways to force lockup on the dyno ask me how
__________________
Yes its as safe or safer than doing it through the PCM use a breakout box or make one, To use in place of the PCM to control the trans , Though it really dosent need to be complicated . You will need some wire,couple switches and and old trans harness. You unplug the trans from the car harness and plug it in. This will leave you in third gear and with the switches you can turn on the TCC solenoid and the PWM solenoid and make full lockup. Note you will set multiple trans codes from having the trans harness unpluged that will need to be cleared when you are done.
Always remember though no matter how its done there are risk to locking the converter and running in third gear on the dyno at max HP to both the converter clutch and the 3-4 clutch set as they were not designed to do that for any exstended period and the lockup clutch was never designed to lockup at WOT ever.
__________________
You would be better to post that question in the tuning section, Some would say if you comand it to lock it should but I have also heard many say thats not the case and I am no tuner
__________________
You can command it to lock up at WOT in tuning. But be cautious about the converter, you can fry one very quickly if it is not designed for that. Multi disk units can handle that, anything else will fail eventually.
I beleave what he is saying is his tuner is comandig lockup at WOT and it isnt happeing for some reason. And I agree it can do damage to the converter.
__________________
Basically to get true RWHP without the converters inherent slip making it lower, Though the car is actually faster unlocked . Mostly for tuning or getting those high numbers like the t56 guys get
__________________
I was really hoping to hear that there is some legit reason that I am missing, other than an inflated dyno number.
Not really other than it can make the numbers a little more stable while tuning
__________________
I'm trying to get everything tuned out. I don't want to leave anything on the table. I can always do a street tune
Nothing on the tranny can be done to fix this problem? Is it really a tuning issue then? Or something w/ the tranny? I care less about dyno numbers becuz A4 are no dyno queen.
Nothing on the tranny can be done to fix this problem? Is it really a tuning issue then? Or something w/ the tranny? I care less about dyno numbers becuz A4 are no dyno queen. Well If lockup does work normally then likley theres some issue in tuning no allowing lockup to occur. Now on the other hand if lockup wont happen period then there may be and issue with the lockup solnoid or the PWM solenoid or even the converter itsself ,Does the converter lockup in normal driving ?
__________________
Then its in the tuning as to why it wont lock at WOT then .
__________________
