Poly engine mount installed on DR side... impressions:
Old Feb 11, 2003 | 08:24 PM
ScottyG's Avatar
Default Poly engine mount installed on DR side... impressions:
I just installed and Energy Suspensions poly mount on the drivers side only. I wanted to try and minimize any y-pipe banging on the floorboard.
Well, it seems to have done the trick. Additional vibration is minimal.. barely noticeable. I massaged the floor a little bit more while I was at it, but the big difference was the mount. Judging from shifter movement (or lack of it) the engine is quite a bit more stable now.... and best of all...no y-pipe problems.
Install was straightforward, but a little bit of a pain in the ***. Had to remove the alternator and the header for clearance. I jacked the engine up an inch or two to be able to slide the mount out of the bracket.
Good mod for a lowered car with the exhaust tucked up close to the body. Every time the clutch chattered (like EVERY time I take off <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> ) the y-pipe would bang the floor. Hasn't banged once since I did this. I was hoping this would do the trick, because I didn't want a bunch of vibration or a torque strap.
Old Feb 12, 2003 | 12:11 AM
Fly By's Avatar
Default Re: Poly engine mount installed on DR side... impressions:
Nice werk!
Hows that clutch? Im putting the same thing in this weekend, Think it would be a good Idea?
Hows about overall motor movement in the engine bay? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 24, 2003 | 10:54 AM
2MCHPWR's Avatar
scotty, is it absolutely necessary to remove the header for this install?
seems like a huge pain the ****.
Old Mar 25, 2003 | 08:38 AM
Fireball's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2MCHPWR:
<strong> scotty, is it absolutely necessary to remove the header for this install?
seems like a huge pain the ****. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I put Energy Suspension mounts on both sides of my engine and didn't have to remove the headers. I have dynatechs so I can't say for certain you can do it with all headers but it WAS a tight fit nonetheless...definately have to remove the alternator.
Old Mar 25, 2003 | 09:47 AM
ScottyG's Avatar
You may be able to do like Fireball and avoid removing the header.
The FLP y-pipe is really easy to get off and I have all the AIR system removed, so taking off the header was only a little bit of extra trouble. The extra room to work with was nice.
If I ever swap the passenger side, I'll probably try it without removing the header since that side is a lot harder to get to the header bolts.
Old Mar 25, 2003 | 10:50 PM
2001 Pewter WS6's Avatar
Restricted User
I just finished up the passenger side tonight. I had the a/c removed already which made things easier. I also removed the starter. I then removed the 4 bolts holding the mount to the block while the jack was under the oil pan with just a little support. I removed the big bolt. I then jacked up the motor far as it would go and the mount slipped out under the header. It was pretty easy. Shoot me an email if you have any questions.
<small>[ March 25, 2003, 10:52 PM: Message edited by: 2001 Pewter WS6 ]</small>
Old Mar 26, 2003 | 12:09 AM
Restricted User
I am in the process of doing this now. I replaced the drivers side. I had to remove the header to be able to get to the top back mounting bolt. The passenger side seems like there is more room. My A/C is off already so I am going to remove the starter and see how easy I can to it. I will update on the passenger side soon. BTW I have FLP headers.
Old Mar 26, 2003 | 12:32 AM
Magnus's Avatar
LS1TECH Sponsor
any drawbacks to a poly motor mount?
I may throw one in when I do my ls1 swap.
Old Mar 29, 2003 | 03:10 AM
1dirtyZ's Avatar
where did you get it from and how much???
Old Mar 29, 2003 | 06:24 AM
kent's Avatar
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I just had the BMR upper and lower A arms install plus the K member. Will there be additional weight savings with the poly mounts? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 29, 2003 | 08:59 AM
ScottyG's Avatar
I got mine from Summit. Part# 3.1116R. It was around $25.
No weight saving kent.
Old Mar 29, 2003 | 09:48 AM
kent's Avatar
Thanks for the reply Scotty G.
Old Mar 31, 2003 | 10:48 AM
2001CamaroGuy's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by kent:
<strong> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I just had the BMR upper and lower A arms install plus the K member. Will there be additional weight savings with the poly mounts? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">not really....were talking grams of difference here.
the gain comes from the removing of engine twist.
The k-member will make it easier to get the motor mounts off.
I wish I had done this when I installed my K-member at Christmas...now I have to go back in and do it <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Chris
Old Mar 31, 2003 | 04:39 PM
Fenris Ulf's Avatar
I installed only the driver's side as well. No added vibration and the engine torques WAY less at idle from my cam.
Old Mar 31, 2003 | 06:09 PM
Raughammer's Avatar
D(irecto)r Pepper
Helluva idea.
And the Tubular K member should help it to not turn into a PITA job.
Thanks for the write up!
