97 Trans Cooler Lines
Old Feb 16, 2008 | 04:57 PM
phantomzer0's Avatar
Default 97 Trans Cooler Lines
Hey guys, I recently had my trans rebuilt. I couldn't get the lines to disconnect so I cut them. I used some rubber hose to reconnect them and now they are leaking.
Does anyone have the GM part number or a set laying around that is compatible with a 97 lt1/4l60e?
Thanks!
Old Feb 16, 2008 | 04:59 PM
stefan256's Avatar
i dont know the part # but you could always run to autozone or advance etc and just take one of the old lines in and they could probably get one to your length and size etc
Old Feb 16, 2008 | 05:04 PM
The problem is that they are pre-bent and shaped to fit perfectly where they belong. I don't just want to run some hose. Thanks for the suggestion though, I really appreciate it.
Old Feb 16, 2008 | 05:06 PM
stefan256's Avatar
yeh didnt even think about that i was thinking about the aftermarket tranny cooler lines.
Old Feb 16, 2008 | 05:28 PM
Yeah, I noticed those today while google searching for the part number. I wish they were just rubber lines.
Old Feb 16, 2008 | 06:29 PM
DRIVER456's Avatar
When I put in my trans coolers I used 3/8 brake line.Maybe you can use that and a flaring tool/brake line bender and some fittings if you can't find anything,Just a thought and not that expensive.....................Paul
Old Feb 16, 2008 | 06:34 PM
angel71rs's Avatar
I've had rubber hose on my 71's cooling lines for years without leaks. I used high pressure fuel line and double clamps; retighten them occasionally, they tend to loosen up as the hose compresses.
Old Feb 16, 2008 | 06:42 PM
3pnt4maro's Avatar
I had to order my lines from NAPA and GM after I cut mine to get the motor out when I rebuilt it...I ordered both of them from GM and the high pressure line was 97 bucks!!!!! the return line I ordered from them and they had it on backorder..so I ended up getting it from NAPA for less than 20 bucks without a wait..
Old Feb 16, 2008 | 08:01 PM
Does anyone offer braided lines? That would be nice!
