fittings on B&M BIG trans cooler...
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have the biggest trans cooler from B&M and the fittings on it are not barbed hose fittings but (very) large female fittings. For those that have installed this cooler, what kind of adapters/hoses did you use???
The Bull
Those are probably 1/2 NPT fittings. You can either get some Aeroquip 1/2 to -6AN fittings or just run some barb fittings. It's up to you.
the threads are 1/2" NPT
trust me on this and if you do not want to use expensive aeroquip fittings/lines it is going to be a PITA to find 1/2" NPT to 3/8" barb
It is easier to buy a 1/2" NPT to 3/8" NPT REDUCER and then use a 3/8" NPT to 3/8" hose barb which is much more common
hope that helps
hope that helps
Went to the hardware store today and guess what they had two left of....
1/2" to 3/8" hose barb![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
What kind and how much hose do I need for this?
