B&M Deep Pans
Based on your listed mods, no you are not at the point that you need one yet.
You want to run the 24000 B&M stacked tranny cooler. If you get to the point of using a higher stall converter and have a tranny saftey blanket on all the time, then you can add another B&M tranny cooler in serial for additional cooling. Then as a last resort add the deep pan to max out the cooling potential.Rick
I have a digital trans temp gauge installed, and live in a hot climate, on the freeway my transmssion temperature stays between 141 and 155 degrees, in town it climbs between 165 to 190. My total fluid change (no converter drain) is 8 Qts.
SteveC
