planet replacement question
Old Feb 29, 2008 | 12:51 AM
LT1driver's Avatar
Default planet replacement question
do you have to remove the valve body or can you leave it on to change a planet gear in 4L60-E, I would like to not mess with it, accumulator etc. if possible. thanks for the imputs.
Old Feb 29, 2008 | 07:05 AM
FLT's Avatar
FLT
It can be done by a well trained individual. The question is why are you changing a planet? If it has exploded or is making metal the whole trans should be disassembled and cleaned throughout.
Old Feb 29, 2008 | 09:04 AM
382ssz28's Avatar
Ditto!
Old Feb 29, 2008 | 09:10 AM
performabuilt's Avatar
LS1Tech Sponsor
Its tediuos but can be done but I too would ask the reasonng for changing it, Generaly as mentioned if a planet fails it will put debris through out the trans . Or if it is whining its sign of a further lube issue in the unit. Now if your doing it just to upgrade to 5 pins and you have no issue at present I would not bother as the risk of issues from doing the change in a good trans are greater than the odds of a 4 pin planet failure,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 29, 2008 | 12:37 PM
LT1driver's Avatar
I wanted to take apart myself to see if that is the problem and if I wanted to tackle the rebuild or take to someone. Lot of work, but I like to tinker with things.
Old Feb 29, 2008 | 12:54 PM
Gilbert@Ace Racing's Avatar
Well I would not recommend you tinker with your own automatic if it is your 1st one to open up. Buy a core, take it apart and see if you then want to tackle yours! Then, if you do open yours up you'll have the replacement hard yous for yours... just and idea.
g
Old Feb 29, 2008 | 07:43 PM
jxaxsxoxn's Avatar
Take the pan off, if theres metal flakes the vb has to come off and come apart.
First 700 I built ran great, no noises, nothing. Just had metal flake red colored fluid, one of the gears was just floating on the pin with no bearings.
Back then I bought a new one from GM for $90, I didn't know I could have had two cores and probably two good planetary sets for $80. So buying a core to take apart and mess with might pay off.
