TH350 no 3rd gear
Old Feb 29, 2008 | 11:06 AM
mdacton's Avatar
Default TH350 no 3rd gear
Any ideas on what it could be?
cheetah manual VB, new trans...1st and second is fine but no 3rd gear
Old Feb 29, 2008 | 11:24 AM
LS1curious's Avatar
recheck your intall. It could be something as simple as a misplaced block off plug or check ball.
Old Feb 29, 2008 | 11:30 AM
Gilbert@Ace Racing's Avatar
It could have a problem in the direct clutch pack.
If you would like to discuss it give us a call.
817-605-3151
g
Old Feb 29, 2008 | 01:58 PM
mdacton's Avatar
Gil, I need to find the instructions from the cheetah VB but I did not install the pin that goes infront of the modulator. So your builder thinks the fluid is just going back into the pan.
Any idea where I can find that part? noone local has one....I will buy one off you if you have it. But pretty sure thats what it is, I build this trans in 2002 and it has been sitting on a shelf since then
Old Feb 29, 2008 | 02:06 PM
LS1curious's Avatar
I am not sure about the fluid routing on that particular T brake but sounds like that could be the culprit.
Old Feb 29, 2008 | 02:40 PM
mdacton's Avatar
well no t-brake on this one turbo action 23253
Here is what I did, I took the modulator out and put the billet plug in. Well I took the modulator valve out also and it should have been left in. So I just ordered one, I will put it in and see what happens.
Good chance I burned it up so might need some clutches anyway.....again
I have built severa stock type trans....this is my first attempt at a racing type trans.....learning curve I guess.
Old Feb 29, 2008 | 03:33 PM
LS1curious's Avatar
Well if the plug was left out most likely no fluid got to the direct clutch so most likely it did not get hosed.wouldn;t hurt to take it apart and check it anyways. The other culprit might be a cut teflon ring on the pump.
