TH350 and stock shifter
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
It is a direct bolt on IF you have a forward valve body. You will have to drill a hole ion your mount bracket to make it align with a bolt on the tranny pan. Other than that, it works the same but you have to remember that 2 on your shifter is now 1st gear. The shifter won't ga all the way to 1 anymore.
Tim
Tim
