Trans damage?
Old Mar 9, 2008 | 06:16 PM
chargedvx6's Avatar
I haven't done WOT in 3rd yet but the problem is in 2nd gear at this stage. Wouldn't be surprised if the clutches are had it, I am just having a run of not the best luck ATM.
Old Mar 9, 2008 | 06:24 PM
Gilbert@Ace Racing's Avatar
Why don't you give me a call tomorrow?
g
Old Mar 9, 2008 | 07:28 PM
chargedvx6's Avatar
I just took it for a drive for the first time since I saw this new problem and now it's gone into limp home mode again.
Will get it scanned for codes tomorrow again.
Old Mar 10, 2008 | 06:20 PM
chargedvx6's Avatar
I just double checked the fluid level and it was quite low. It took 1.5L/ 3.2 pints and now it isn't going into limp home but is doing the slip thing. Hard to describe so here is a Photobucket link to a vid of what it is doing. The 1st one is it shifting normally through the gears on low throttle:
http://s173.photobucket.com/albums/w...ottlegears.flv
The 2nd one is full throttle. The 1-2 shift lets go and grabs again then in 2nd it seems to kind of rev limit before the change to 3rd. I didn't want to push it more to see if it would actually shift into 3rd:
http://s173.photobucket.com/albums/w...rottleslip.flv
Old Mar 10, 2008 | 07:20 PM
Blackhawk777's Avatar
The clutches are toast. Time for a rebuild/replace.
Old Mar 11, 2008 | 12:09 AM
chargedvx6's Avatar
Just scanned for trouble codes and got the 2-3 solenoid circuit failure again. Ideas?
Old Mar 11, 2008 | 12:17 AM
performabuilt's Avatar
LS1Tech Sponsor
I would still just change the solenoid first
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 11, 2008 | 02:39 AM
chargedvx6's Avatar
The thing is last week I dropped the pan and tested resistance on all solenoids and got 24-26ohms on all 5 so they were functioning (I think?) but I swapped the 1-2 and 2-3 over to rule out the solenoids.
That points to an electrical fault in the loom somewhere or a physical fault like a stuck valve or accumulator I guess. I was sort of hoping for some tips on what parts act on the 2-3 circuit so i can maybe take them out and check them.
On your advice I got a pro to check all the fuses and relays and all were o.k. so I am at a loss for what to do next.
I am thinking of replacing the solenoid loom and solenoids but that is really pricey for what is probably a simple fix.
It is also throwing an intermittent TPS fault code on the dash but on the scan tool there is no history of that code???
Could the TPS be tricking the PCM into false shifting?
Anything you can think of is great because I am at a loss
Old Mar 11, 2008 | 02:45 AM
chargedvx6's Avatar
Originally Posted by LS1curious
try cleaning the PCM connectors and the connector at the transmission it self. Occasionally I get a poor running f-body in with corroded connections and or water intrusion after a good washing.
Where are the PCM connectors? Our layouts are vastly different but a general point in the right direction may help.
Here is a pic of my Engine bay. The fuses and relays are in the black rectangular box on the left of pic and there are 3 plugs off the loom at the top left of the pic behind the strut that look pretty major.
Old Mar 11, 2008 | 07:07 PM
chargedvx6's Avatar
I just fitted a new TPS in case it was that because I got a TPS fault code. The code is still there after the new TPS.
Old Mar 12, 2008 | 06:10 AM
chargedvx6's Avatar
Reset the ECU which cleared the codes after fitting a new TPS and just went sideways up the street for the first time in weeks
I didn't go to somewhere to open it right up yet and it seems too good to be true, will keep you posted.
Old Mar 12, 2008 | 09:16 AM
  #32
What year is the car?
It could be that the PCM is throwing a TPS code because it "thinks" the TPS is reporting incorrectly because of the Converter or other powertrain mods. '98's are bad about that.
g
Old Mar 12, 2008 | 04:23 PM
  #33
chargedvx6's Avatar
g
It's a 2002 model. Thing is it's an Australian L67 rwd platform car so our 02 4L60E might not be the same as the boxs you guys got in 02. 4HDD is the prefix on the box I think.
U may be right about the code being an indirect sign of something else, a few people have told me similar. Torque management isn't the same on the L67 ECU as it is on the LS1etc. Doesn't limit torque apparently but I have a feeling the new TPS won't be the end of story yet
Old Mar 12, 2008 | 06:25 PM
  #34
chargedvx6's Avatar
Still doing it. If I turn the car off and start it again it will go out of limp home (2nd and 3rd gear only, no lock up) and just do the jumping thing some times at WOT.
Getting confused now
