th400 question......help!
Old Mar 9, 2008 | 02:48 PM
bLuE_DeViLz28's Avatar
Question th400 question......help!
is there suppose to be a spacer or washer between the filter and the valve body that the bolt goes through? bc when i took the trans cover you can move the trans filter up and down but the bolt is screwed all the way in. and the transmissions is in a 1970 olds cutlass
Old Mar 9, 2008 | 05:40 PM
Gilbert@Ace Racing's Avatar
Does it have a deep aluminum pan on it? If so then there is a filter extension missing.
If it has a stock pan then you need the correct filter screws.
g
Old Mar 9, 2008 | 07:09 PM
its stock. i want to get freakin thing figured out. at the ssame time im putting new brake system in
Old Mar 9, 2008 | 07:11 PM
performabuilt's Avatar
LS1Tech Sponsor
The guide bolt for the fliter in the 400 will allow some movement. Note how its threaded then gets larger with no threads where the filter rides on it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 9, 2008 | 07:20 PM
FLT's Avatar
FLT
I think Gil you meant to say filter screw/bolt. If using a factory shallow pan, the bolt has a shoulder on it. No spacer required for the bolt. If using a deep pan, then a spacer is used along with a longer bolt with a shoulder on it that is used as a stop. With either pan a shorter or longer filter extension is used depending on the pan depth. In either case the filter is loose fitting and what you are seeing is normal providing that the correct pieces have been used. Post up some pictures is you can. This will better help us to tell you that you have the correct pieces or not. Vince
Old Mar 9, 2008 | 08:44 PM
Old Mar 9, 2008 | 08:45 PM
down
up
Old Mar 9, 2008 | 08:47 PM
down
up
Old Mar 9, 2008 | 08:48 PM
down
up
Old Mar 9, 2008 | 08:49 PM
if you can see it left imprints in the pan from moving around
Old Mar 9, 2008 | 08:50 PM
Old Mar 9, 2008 | 08:51 PM
Old Mar 9, 2008 | 08:59 PM
FLT's Avatar
FLT
That is the right bolt for use with the pan you have. Vince
Old Mar 9, 2008 | 09:50 PM
vince
but is the filter suppose to move up and down?!!?? for me i dont think the filter is supposed to move around and it does move side to side alittle bit. am i missing anything to keep it from movin around??????????
Old Mar 9, 2008 | 10:29 PM
FLT's Avatar
FLT
No thats just the way the 400 is.
