A Stall...
Old Mar 10, 2008 | 11:48 PM
99Hawk262's Avatar
Originally Posted by 98REDZ
You order a 4000...your extensions will be higher than 4000. My Fuddle 4000 2.5STR shift extensions are at 5200rpm....meaning when I punch it....its instantly there and doesn't go below.
For comparison sake, my SS4000 with a 2.5 STR had a ~4900 RPM shift extension with 6000 RPM shift points. So the Fuddle appears to carry that a little higher which is nice. My PT4400 has a ~5800 RPM shift extension with 6500 RPM shift points.
Old Mar 10, 2008 | 11:50 PM
98REDZ's Avatar
Yeah from what I hear from alot of my friends....my stall is quite a bit more loose than theirs. extensions to 5200rpms and shifts at 6950rpm for me.
Old Mar 10, 2008 | 11:51 PM
waterbug1999's Avatar
Im not sure where my extensions are at... I am too busy holding on!
Old Mar 11, 2008 | 12:03 AM
99Hawk262's Avatar
Old Mar 11, 2008 | 12:05 AM
98REDZ's Avatar
Personaly wouldn't know if it weren't for the dyno.
Old Mar 11, 2008 | 12:15 AM
99Hawk262's Avatar
I only know by looking at tune logs.
1/4milerunnerZ28's Avatar
Smile
is it better to have it start of at 4000 rpms or closer or 3000 rpms. wouldnt you run out of range sooner?
and does the stall only work when you take off. after first gear i mean, then does it just act like normal shifting...
so i guess im asking does the bigger number on the stall mean it will take off the line faster....
and what does the slipping and loosenes mean...
Old Mar 11, 2008 | 12:26 AM
Smile
Originally Posted by 1/4milerunnerZ28
some guy is selling a performabuilt 3800, have you ever heard of this brand? And so is it any good? It has 1,500 miles and 6 drag passes on it...............He is selling it for $300 shipped.... is that a good stall
actually this guy only wants 250$ shipped...
which would make this a good deal.
But if anyone knows of anyone who is selling other really good stalls i would like to be notified..
thanks again for all your help..
Old Mar 11, 2008 | 12:54 AM
sixvi6-camaro's Avatar
Stall helps just about all RPM's.. see the video I posted below and watch the Tach during the last Wide open run. in a stock stall car the RPM's would drop to probably 3000 rpm and fall out of the powerband during the shifts. My vid with the stall the car never goes below about 5000 rpm between the shifts (5000 rpm shift extension) keeping the car in the Powerband at all times. You won't run out of range at all.. LS1 love high RPM stalls and make great power all the way to redline.
Anyways here is a video of my Vig 3600 stall (actually acts more like a 4000 stall in reality) .. pretty normal driving Although I did get on it a little leaving the parking garage. then some full throttle stuff at the end. you can see to keep up with normal traffic its not using a lot of RPM's at all. usually no more than 2500-3000 rpm at the most. The only downfall is stalled cars get a couple MPG worse mileage in the city. highway MPG will not change.
View Video on FQuick
Old Mar 11, 2008 | 05:56 PM
TA1364's Avatar
Originally Posted by 99Hawk262
And no, I'm not a salesman for Yank, I've just always run them because they've always worked well for me. Now that he's got the three warranty, it'd be hard to pass that up. There are other manufacturers that are proven as well, namely Vigilante. You'll hear bad things about Fuddle, but if circumstances had been different when I purchased my first converter, I could just of easily ended up with one of those.
I no im just giving you crap.
Some of the examples you have said in the past helped me decide on ss4000
Old Mar 11, 2008 | 07:10 PM
99Hawk262's Avatar
How do you like it? It's a great dd converter.
Old Mar 11, 2008 | 09:43 PM
  #32
TA1364's Avatar
Its at the shop right now getting that, LTs and Ory. Might have it back tomorrow latest thursday. I'll make a thread with a review of it.
