Shift kit...
Old Mar 10, 2008 | 08:07 PM
1/4milerunnerZ28's Avatar
Exclamation Shift kit...
What a good shift kit for the price, and where is the best place to get them....
Old Mar 10, 2008 | 09:06 PM
FLT's Avatar
FLT
HD-2 kit from transgo is the most popular and the only one we use here at FLT.
Old Mar 10, 2008 | 10:26 PM
is this product easy enough to enstall with a lift and simply mechanical skills.. or does it require a shop? and would you recommend installing a the stall at the same time... save time...?
Old Mar 11, 2008 | 06:43 AM
FLT's Avatar
FLT
I guess it would depend on ones mechanical abilities. I will say with a lift anything is easier. In some cases a qualified shop is better for some individuals but that would depend on your abilities. If you are going to install a converter then that is the time to install the kit and or have the unit freshened up.
Old Mar 12, 2008 | 11:35 PM
thanks alot... i have a buddy with a lift and mechanical skills.. thanks alot for your help
