Engine braking
Old Mar 13, 2008 | 10:28 AM
rmpitzer's Avatar
Default Engine braking
I have a strange problem, I wonder if anyone else has had a similiar issue. I tried doing a search, and didn't come up with much. I'll try to describe it as best I can......
I have a 97 TA with an A4. Normally the car drives fine, and at highway speeds, if I let off the gas pedal, the car coasts fine....the tach stays right where it was when I had my foot on the pedal. But occasionally when I let my foot off the pedal, I feel a noticable engine braking. The odd part is, the tach is at the same RPM at the same speed (ie, 2000 rpm @ 62 mph). On top of that...when this weird engine braking is happening....when I come to a stop, the engine idles at a noticebly lower rpm (a tad over 500), and it stumbles a bit when I give it gas.
At first I thought it was a tranny issue (a tranny that was rebuilt 10,000 miles ago)....but....when the car is idling low, if I pop it in neutral, it still idles low....which makes me think it's an engine problem. I get no trouble codes, and the engine seems to be running fine.
Before I bug the tranny shop about a problem that may not be theirs, I thought I'd see if anyone here had any thoughts?
Old Mar 13, 2008 | 10:33 AM
Gilbert@Ace Racing's Avatar
Well I'm not sure if it's a tranny problem either. I recommend taking it to someone who can data log the tranny and the engine pids to see what is happening and why.
Good Luck with it.
g
Old Mar 13, 2008 | 02:16 PM
Rhedalert's Avatar
that sounds like Decel Fuel Cutoff is kicking in. That's how it feels on my car and I can confirm that's the cause based on scanning w/ HP Tuners. In fact I changed the settings on mine to enable earlier. Hope this helps.
Old Mar 14, 2008 | 03:30 PM
rmpitzer's Avatar
Thanks for the replies. I don't see any mention of Decel Fuel Cut off (DFCO- I've learned from searching this forum) in the factory service manual, but I may not have looked in the right place yet. I'm not sure it would explain the lower idle I am seeing, did your car do that when you had the problem?
But it's a place to start looking! Thanks again!
-Rich
Old Mar 14, 2008 | 03:52 PM
Rhedalert's Avatar
my idle is always low once it's warm, around 500-550rpm. I don't see much fluctuation however.
Old Mar 14, 2008 | 04:32 PM
rmpitzer's Avatar
Hmmmm, interesting. Mine idles around there when I have this issue.....when I don't, it idles around 750.
Old Mar 14, 2008 | 09:36 PM
unbroken's Avatar
Decel Fuel Cutoff???
