TH400 Driveshaft question???
Old Jul 23, 2003 | 01:06 AM
DOC OTIS's Avatar
Default TH400 Driveshaft question???
I already have a Mark Williams chromoly driveshaft that runs between a M6 and a Moser 12 bolt rear end. My question is when I convert over to a TH400 can I just have that drive shaft cut and re-balanced or do I need a longer driveshaft? I really don't want to buy a different driveshaft if it isn't necessary.
Old Jul 23, 2003 | 08:15 AM
Black Sunshine/ 00SS's Avatar
Default Re: TH400 Driveshaft question???
I believe that you will have to have it longer. A good machine shop can make it longer for you. I had to get one that was longer. You might as well get a new one, because the yoke is different also. Good luck.
Old Jul 23, 2003 | 09:18 AM
DERTY's Avatar
The Bull
Mine measured in at 47" from the flange of the tranny to the center of u-joint. I'm not sure what that works out to for the driveshaft length, but it's definitely a few inches longer than the stock length.
