Does your 400T clunk hard when you put it into gear?
Mine does. It sounds like it is coming from the rear. Maybe I have to much play in the pinion. Is it normal to have a slight hit when going into gear, reverse or D? It sometimes will do it when in gear. I have to break in the motor, so I have not it it hard yet. I just wanted to be asured that it would hold up. It is a new U-joint. Thanks.
