Tranny Cooler
Old Mar 17, 2008 | 08:03 PM
1BDBOTI's Avatar
Default Tranny Cooler
I just purchused a ACE tranny, level 2 4L60E, vac modulated, 3500 Stall..... I was wondering if my stock tranny cooler is good enough, or should I buy an aftermarket with fan, if so what size cooler and fan, where can I get one???
Old Mar 18, 2008 | 04:08 AM
BLOWN SS/T's Avatar
Bypass the stock cooler, and run a b&m 24k trans cooler. Just make sure all the clamps are tight, and you'll be good to go.
Old Mar 18, 2008 | 08:09 AM
nahasapeemapetalon's Avatar
Just bought a B&M #:BMM-70274 and mounting kit #:BMM-80278 and installed in front of my AC condenser cooler.
Old Mar 19, 2008 | 08:23 PM
1BDBOTI's Avatar
should i use a fan
Old Mar 19, 2008 | 08:38 PM
383lt1impala's Avatar
if u live in really not weather then yes. i live in southern california it gets pretty hot here and i dont need one.
Old Mar 19, 2008 | 09:02 PM
GregWS6&z28's Avatar
i have a B&M 24K and after that goes through the stock cooler and cools just fine. it usually runs around 160 degrees. mines mounted dope style
Old Mar 19, 2008 | 11:18 PM
jsteele90's Avatar
so when u say bypass the stock cooler what so u use to plug the holes where the lines used to run? just some bolts or something? isnt the factory cooler just part of the radiiator?
Old Mar 20, 2008 | 04:44 AM
JEB99TA's Avatar
I wouldn't bypass the stock cooler. I did it twice and both times it caused my temps to go up about 10-15* in the Florida heat. The stock cooler integrated within the radiator was engineered that way for a reason. Though the engine temps reach upwards of 210* in extremely hot conditions, if the thermostat is doing it's job, it opens and allows 'cooler water' to enter into the motor to keep it cooled down.
In Ohio, you wouldn't prob see much difference whether you bypassed the stock cooling system or not, but, why not keep it running as cool as is possible. You constantly have cooler air moving through the radiator keeping it cool .. when not moving, you still have the radiator housed in metal ... thus providing somewhat of a cooling effect, as well. Stick with not bypassing the stock cooling system.
Old Mar 20, 2008 | 08:51 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Honestly having a cooler even on a stock trans is a good thing. B&M makes one where it will be bypassed until it gets up to temp then run both. So it wont over cool.
Old Mar 20, 2008 | 09:14 PM
I am not going to use a fan, I am installing a trans temp gauge. I am sure it will be fine, if not then i can look into more options. I think with a big b&m like mine you would be fine, I have seen others with the same setup be just fine.
Old Mar 20, 2008 | 09:46 PM
http://i173.photobucket.com/albums/w...DSC02821-1.jpg
http://i173.photobucket.com/albums/w...m/DSC02820.jpg
http://i173.photobucket.com/albums/w...m/DSC02844.jpg
Old Mar 22, 2008 | 07:42 AM
JEB99TA's Avatar
nahasapeemapetalon
Nice mounting location w/ lines.
Old Mar 23, 2008 | 07:57 PM
JEB99TA's Avatar
Tore into my car today and moved the 29.200 GWV to the same location you have yours mounted and it's running 10-15* cooler. Thanks for posting the pics. I got your PM and will look into the braided lines ... they look very nice over the rubber stuff! Thanks for all the info and Happy Easter brother!
