stall question?
Old Mar 18, 2008 | 04:24 PM
Three50_lt1's Avatar
Default stall question?
whats the biggest stall i can use with my stock heads and cam??
Old Mar 18, 2008 | 04:28 PM
98REDZ's Avatar
bout as big as you wanna go with. I ran a loose 4000 with no problems on stock head/cam for a long time. You'd be fine with a 4400 if ya wanted, your shift extension wont be too much since your closer to stock.
Old Mar 19, 2008 | 05:38 AM
will i notice a change in power and will it harm anything??/
Old Mar 19, 2008 | 06:07 AM
Razor_Blade's Avatar
Judging from the screen names the op has an LT1 and the guy that responded has an LS1. The LS1 has a much higher power range than the LT1. Your stock LT1 would most likely be a dog 4000+ stall.
Most bolt on LT1 cars are running something in the 3000 to 3200 range. There are several sponsors here that offer converters. You should try contacting them and tell them what you have and what you are trying to do with the car. They can most likely set you up with something that fits your needs. Look in the sponsor list to the right and you should find Performabuilt, Ace Racing Transmisions, Yank, and Circle D.
Old Mar 20, 2008 | 02:50 PM
great thanks man.
