trans cooler necessity
Old Mar 1, 2003 | 02:12 PM
transamgod's Avatar
Default trans cooler necessity
why do vigilanty torue converters say that no aux tran cooler is needed but every other converter says recommended?
Old Mar 1, 2003 | 02:27 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: trans cooler necessity
I don't care what coverter you've got, you should ALWAYS use a cooler, IMO. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Hell, I even put a cooler on with my stock TC, but with a higher stall it should be a given.
Old Mar 1, 2003 | 10:17 PM
2001CamaroGuy's Avatar
do you need it....perhaps not...should you use it....DEFINATELY!!!!!
Cooling that tranny down some is ALWAYS a good idea (I know....can get too cold but not often). If I'm right, don't the A4s have a small cooler that goes into the engine radiator (I know my old Intrepid had that)? If so, then adding another tranny cooler will keep from putting as much heat into the engine fluid and will help the engine run cooler.
Chris
Old Mar 3, 2003 | 08:09 AM
Kevin Steele's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 2001CamaroGuy:
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If your trans fluid runs from the trans to the radiator cooler to the external cooler back to the trans, then you will have maximum cooling potential (any application). If your trans fluid runs from the trans to the external cooler to the radiator cooler back to the tranny, then the radiator fluid will heat your trans fluid. (stock application)
Kevin Steele
<small>[ March 03, 2003, 08:12 AM: Message edited by: Kevin Steele ]</small>
