Has anyone installed braided cooler lines for 4L60E?
as in the Subject line . . . I'm interested in hearing about experiences with
this, even if you ONLY ran the lines from the tranny for a couple of feet.
Photos would be great, in addition to parts used.
(also posted over in camaroz28.com / z28.com)
I am in the process of doing this. I have two fittings to go on the transmission. I am using aeroquip snap lock line
1/4" and 6AN X 2 (transmission fittings)
45 degree 6AN snaplock fittings X2 (you would use the 6AN fittings for braided hose)
90 degree 6AN snaplock fittings to go on the trans cooler
1/2" Npt and 6AN X2 to go into my trans cooler
If you don't have a trans cooler that you can use AN fittings with you could use hose clamps to connect it to the barb fittings
I will post up some pics when I finish this project
