4l60e ???
Old Mar 24, 2008 | 07:10 PM
smokeyrider05's Avatar
Default 4l60e ???
i have a 1998 trans am and the trans just gave out. i was wondering if a 4l60e trans from a 95 2 wheel drive jimmy would work it i swapped out the tail housings?
Old Mar 24, 2008 | 07:40 PM
performabuilt's Avatar
LS1Tech Sponsor
No it will not , sorry
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 24, 2008 | 10:23 PM
mean_greenZ's Avatar
arent the 60e's in the f-bodies set up to shift a a lil firmer than the ones in the suv's and such?
Old Mar 24, 2008 | 11:44 PM
MikeG's Avatar
From the looks of your setup, you should definitely upgrade to a solid, built tranny. Looks like you're trying to save $$$, which is understood, but if you just do it right this time you won't keep blowing through transmissions. I don't know for sure, but I imagine a 4L60 from a Jimmy wouldn't last a week in your car.
Old Mar 27, 2008 | 11:43 PM
thanks guys, built trans is on the way, almost got the money.
Old Mar 28, 2008 | 10:53 AM
Gilbert@Ace Racing's Avatar
If you have not already decided on which unit to go with, give me a call and we can explore some options you may not be aware of!
817-605-3151
Good Luck !
g
