Code P0751, solenoid in 4l60E not working, which one???
Got a code, pulled P0751, talked with trans guy here, he said that a solenoid was not working (controls shifts, and is located on the valve body). I called GM dealer to get part, and there are apparently 3 solenoids...one for 1-2, one for 2-3, and one for TCC. Does this code P0751 refer to one of these specifically, or do I just replace the one I think it is?
Thanks,
SDB
Thanks,
SDB
Re: Code P0751, solenoid in 4l60E not working, which one???
P0751 refers to shift solenoid A stuck off, which according to the manual I have should be the 1-2 shift solenoid. If this one is stuck off, you should have 2nd and 3rd gears only. Both of the shift solenoids are identical. The 'A' solenoid is the one closest to the manual valve.
