Anyone have a problem with a bog down in 3rd gear from a 30 roll?
Thanks
Matt
Doesn't bog, lug or anything, just pulls up to the speed I want to be at, then I put it up into "OD" and go about my merry way.
I had my tuner reset the values on my converter for knock, and it locks and unlocks fine at the mph I want it to.
Probably your best bet is to do what Frank posted and have the car scanned while it's acting up. See if the PCM is commanding the converter to lock up or not. It shouldn't be letting it lock up at 1/2 throttle at all unless it's tuned to do so.
Again, I'd find someone who tunes, or possibly go to the local transmission shop, they usually have scanners that can see what data is being transmitted to and from the transmission.
How much throttle do you have to give the car before it unlocks in 3rd?
What position is the selector in?
Have you tried it with the selector in both "D" and "OD"?
What brand and size converter?
Do you have it tuned for the converter?
Give a little more info and folks here on the board may be able to help you figure it out.
Unless you changed something, anything, then there is most likely a failed component. IE: KR sensor, O2 sensor, etc...
The single most important thing I have learned in well over 20 yrs of diagnosis Driveability concerns is the fact that you must repair the obvious first. In your case that means you must determine why it is reporting KR, probably an exhaust change issue... and you must determine why there are O2 codes. If it is as simple as Tuning, then hire a Professional to do it right the 1st time and be done with it.
There really is no way for us to be able to determine the source of your converter staying locked up at WOT without having the car. We can only make suggestions.
Hope that helps.
g
Is there a shop in your area that you trust o take a look at it ? ... preferrably a performance shop
g
