stall......good or bad from the roll???
by the way, i don't understand how a pt4400 can be faster from a roll. i know the shift extensions will be better but if you don't start until you are going 50 or so then you will only have one shift.
It's the way Yank designed the PT series. They are the fastest, baddest NA converter you can get IMO. Yes, shift extension helps.....but the PT series are extremely efficient and that plays a part as well.
On my car, punching it from 50 MPH will drop it into the meat of 2nd gear. It'll then shift into 3rd at ~75ish and the RPM's only drop to ~5800. 3rd will carry to ~145ish....but the pull never slows down like it did with the SS4000. Obviously my setup has a lot to do with that, but my car pulls better from 120 and up than it does below that.
Also, most stalls for ls1s are lockup. I have mine tuned to lockup in 4th gear only at under 70% or so throttle, so my highway driving is no different from the stock stall. Its in the PCM tune, mine was done with hp tuners by rhino79
"Some car enthusiasts put all kinds of money in the engine, transmission, torque converter, NOS, rear end gears, etc. then want to cripple the torque converter by lowering the STR to try and prevent wheel spin on take off. This is as foolish as pulling off one of the plug wires. "
Any good converter is going to give you a substantial boost in performance over a stock one. You won't be worse off at all.
These videos speak louder than words.
http://www.fquick.com/videos/99hawk262/4590
http://www.fquick.com/videos/99hawk262/4649
I've driven 99hawk262's car before and honestly it feels like my car cruising around town. FYI, I have his old Yank ST 3500 converter.
Who the hell races from a 60mph roll anyway? hahahah!
in that second video, what were the mods on the car that was videotaping?
