need help! 4l60e
Old Apr 4, 2008 | 04:53 PM
stangkiller2005's Avatar
Default need help! 4l60e
ok so i have a stalled auto.
was driving home from picking up my little brother. car was driving normal. shifting fine. i pull into the driveway. drop off my brother and put the car in reverse. i didnt go nowhere! WTF! the car still drives forward but wont go in reverse. just sits like if it were in N. and another thing when i put it in neutral it freakin goes forward like if it were in D! WTF? in Park, it moves abit like if it were trying to go into gear...has anyone ever had this? heard of this? is my tranny royally fukd!?
Old Apr 4, 2008 | 05:27 PM
super_fro_daddy's Avatar
Sounds similar to my mother's '97 Chevy truck (which is also 4L60). It had no reverse, but the forward gears worked ok, but when you had it in OD or D it wouldn't shift out of first gear. If you put it in 1 or 2 it shifted good but slipped pretty bad off the start.
I'm sure the Performabuilt, FLT, or Ratchthed will chime in and be able to help you better than I can.
Old Apr 4, 2008 | 05:39 PM
thanks bro! yea hopefully they chime in.
all my forward gears work fine. seems to go good manually into 1st,2nd, 3rd, 4rth. and while shifting automatically aswell. just reverse, neutral, and park feel weird. my pops was telling me that the thing that moves by a cable when manually putting the car into gears probably moved or someting. that it un-adjusted or something. and thats why in neutral it moves forward, and park it acts up alil bit. but im not sure. hopefully its just something that needs to be adjusted.i dont have any SES light either.
Old Apr 4, 2008 | 05:53 PM
performabuilt's Avatar
LS1Tech Sponsor
If by weird you mean that in neutral it trys to go forward and in park wont rev well and in reverse are like the brakes are on, Then you have a seized forward clutch and yes you have a serious transmission issue,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 4, 2008 | 07:45 PM
heymoej's Avatar
hey man long time no see! lol. sorry to hear about your trans problem,been there done that! pm VINCE @ FLT or GILBERT @ ACE who ever you are closer to & these guys will fix you up right the first time,they did me! good luck bro & let me know if i can help you out in any way! john
Old Apr 4, 2008 | 11:18 PM
yea in reverse the car does nothing. just sits. and wont roll back either. car will roll back with car off. when in neutral the car acts like it is in drive. in park it kinda feels like the car is not compleatly in park. i can kinda feel like it slightly pulls forward, but not enough to move the car.
Old Apr 5, 2008 | 12:09 AM
LS1Tech Sponsor
Seized forward clutch sorry
__________________
Call 888-744-6542
Old Apr 5, 2008 | 01:46 AM
really?
so basically means i need to rebuild or get a new one?
Old Apr 5, 2008 | 10:13 AM
TTS's Avatar
TTS
You need a rebuild, the forward frictions "welded" themselves to the steels.
Old Apr 5, 2008 | 11:30 AM
LS1Tech Sponsor
really?
Yes unfortunatly you will need to get that one rebuilt or get another trans. Sorry I know unexspected exspenses suck.
__________________
Call 888-744-6542
Old Apr 7, 2008 | 09:37 PM
question for you guys!
will a v6 auto work with my car? or are the trannys different? this would just be for until i have money for a built one.
Old Apr 7, 2008 | 10:48 PM
yay or nay?
Old Apr 7, 2008 | 10:54 PM
heymoej's Avatar
nay.............
Old Apr 7, 2008 | 11:00 PM
dam
Old Apr 9, 2008 | 10:11 PM
hey guys!
guess wat! lol. my tranny started working again! rolled it outta the driveway. and just drove it around the block. then tried the Neutral, and Reverse they started working! and no more problems in Park either!
defenatly a good day! still mite go with a 6 speed later on tho.. not sure.
