Quick Converter install question
Old Mar 9, 2003 | 08:48 PM
99taws6's Avatar
Default Quick Converter install question
When I install a converter vig 2800 or 3600 and I get it to slide in all the way 3 clicks, how hard should it be to turn? Should it turn over with some resistance?
Old Mar 9, 2003 | 10:03 PM
99taws6's Avatar
Default Re: Quick Converter install question
ttt
Old Mar 9, 2003 | 10:31 PM
trackbird's Avatar
You won't be able to spin it with your finger and have it turn 4-5 times or anything like that. If you get a firm grip on it you should be able to move it (it will turn, not "spin"). You are turning the front pump with the convertor case and you will get resistance from that as well. As long as you have it seated all the way, and it is not stuck in place (meaning, won't turn at all) then you should be fine. Hope this helps, good luck!
Old Mar 9, 2003 | 10:38 PM
99taws6's Avatar
Ok, thanks. That is the way mine is.. I tried it with both converters I have and it was the same with both, just wanted to make sure...
