TC Phobia, please help!
Old Jul 31, 2003 | 05:29 AM
4thGENRETARD's Avatar
Default TC Phobia, please help!
Please help me make up my mind. I've heard and read so many stories, I think I've develloped TC Phobia!
I know the benefits of a higher stall TC. What worries me is the adverse effect on the tranny. Will changing to a Higher Stall mean eminent premature tranny DEATH?
Is there a stall range that is worth the mod (in power gain) but is merciful to the tranny?
I'm thinking 2800? or 3000? or 3200?
All comments dear to me.
Thanks
Please consider I live in TX, VERY VERY HOT
Old Jul 31, 2003 | 06:39 AM
Fast SS on TNT's Avatar
Default Re: TC Phobia, please help!
#1 killer of all automatics is heat. The higher the stall the more heat it will generate.
Okay, keeping that in mind you MUST go with an aftermarket cooler. The bigger the better is the best way to approach the subject. Go with a 24-28K GVW Cooler with a good fan added.
Size? Its a matter of choice, I like big stalls. But you should get some more input from the other members on this board. Have Fun! FSSTNT
Old Jul 31, 2003 | 07:35 AM
PonchoFan's Avatar
A. A converter with a cooler won't hurt your tranny.
B. Performance gains vs. dollars spent is the best deal out there for an A4.
C. Getting the right converter can usually avoid a rear gear change. A
higher STR converter will hit harder and drive better as a daily driver
at the expense of torque multiplication dropping off faster than a low STR
converter.
D. Do your research upfront as to what one to buy. '01s/'02s may need the
torque management deleted. There are a bunch of good choices out there.
The VAST majority want more stall after their initial purchase so keep this
in mind when choosing one. Even if restalls are free, shipping and installation
costs aren't.
Old Jul 31, 2003 | 09:23 AM
horist's Avatar
....I like big stalls and I cannot lie... u other brotherz can't deny, when a car pulls up with an itty bitty sound and a stall up in ur face u get sprung want to pull up tough
er um... I like big stalls go w/a Vig 3200 or 3600 and you'll be fine...
I've gotta 3600 in mine now... prolly up to a 4400 next year
Old Jul 31, 2003 | 10:16 AM
Vig 3600, I've been reading here that this really not their true stall, more like 3800 or 4000.
Still I read that pumps are the first to go with added pressure. Is this common with a TC change?
Old Jul 31, 2003 | 01:16 PM
PonchoFan's Avatar
The pump is vulerable to to a converter clutch lining coming apart.
Higher pressure may take out the valve body.
Clutch packs in the trans may fail if h.p. is increased substantially.
A great converter with 3.73s is a Yank SY3500.
Old Jul 31, 2003 | 05:27 PM
Colonel's Avatar
"Vig 3600, I've been reading here that this really not their true stall, more like 3800"
True. It's also a pretty inefficient converter.
Get a nice 3500-3800 stall (true stall speed...as mentioned, Vig underrates their stalls for some damn reason) and a tranny cooler and you'll be good to go. I also like the TQ management deleted and a good shift kit such as TCI's.
Old Jul 31, 2003 | 07:25 PM
Thanks for the help guys. Yank had suggested SY 3500. but I don't want a loose car, its my daily driver. Could I go with a 3200 to be on safe side?
Old Jul 31, 2003 | 07:54 PM
Colonel's Avatar
Wait a minute, says in your sig that you run ET Streets at the track. If so, Mike at Yank must not have realized this or he wouldn't have suggested the soft hitting SY3500 (which btw, is not too loose for everyday driving by most accounts...especially with the 3.73 gears in your sig.)
Old Aug 1, 2003 | 03:04 AM
I guess I should give him a call again. I just got the ET's. When I spoke to Mike, I was still running Yoko's AVS Sport. (Which hook well for a street tire). Will see what he says. My goal for the moment is to run low 12's. My best was 13.01@106 but my 60' sucked at 2.1 and that was with 3:23 on Yoko's with 20lbs pressure. LT's and TC are a must for my next mods and LCA's with poly bushings for sway bar and TQ arm to plant all of that. Hope I'm in the right direction.
What do you think Colonel? Thanks for all ur input .
Old Aug 1, 2003 | 11:29 AM
Colonel's Avatar
I think Mike would recommend a converter with a higher STR than the SY3500's 1.65.
Here's my recommendation...
Get a TCI 3500-3800 or a TCS 3500-3800 with a really high STR (that's Stall Torque Ratio.)
Get a tranny cooler.
Don't expect the LCAs, bushings, and TQ arm to noticably improve traction. The stock stuff works just fine for an A4 all the way down to 1.4 60ftland.
Reset your goals to 11s. Low 12 will come alot easier than you think once you get headers, a good converter and some traction.
Old Aug 1, 2003 | 11:38 AM
Patrick G's Avatar
LS1 Tech Administrator
Colonel is right on with his recommendations: 3600-3800 stall...high stall torque ratio. My favorite by far is the Yank Super Stock 3800.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 1, 2003 | 11:57 AM
MadIceV8's Avatar
Customizing Director
Thats how I was thinking at first, but ended up not getting the times I expected at all . I have a Vig 3200 Converter (with tuning) and was hoping to hit at least 12.4, and well as you can see my best has only been 13.1@105. But I guess its mainly because I have a 2in drop, ran with the 18's, and have 2.73 gears.
SHARKYMARK - Right now your doing better then me and don't even have a converter yet. Also kind of baffled how your 2.1 60ft beats my 1.9? And didn't you still run that 13.0 with the 18's? As you can see I'm still somewhat new to this, not too happy with my time.
Old Aug 1, 2003 | 01:28 PM
MadIce,
This was my best time and it is not consistant. On average I was running more in the range, 13.04 even 13.05+
I haven't gone to the track with the ET's yet and I've added 3:73s. I'll see what's happenning when I do.I like your ride height, mine is stock. From what I read around lowered rides launch slower, something to do with weight transfer. Also I took my car on a diet and it only weighs 3740 lbs with me in it and very little gas. Around 3560-3580 without. I was hurting on the 60 ft mostly because of tire spin.
Old Aug 1, 2003 | 01:47 PM
Colonel's Avatar
"But I guess its mainly because I have a 2in drop, ran with the 18's, and have 2.73 gears."
Uhh, yeah, that might have something to do with it!
With 3.23 gears, a stock weight car with an internally stock engine, and Nitto drag radials, I pulled a 1.61 60ft time. Gimme ET Streets and 3.73s and I'll pull mid to low 1.5s.
Don't expect good ETs if you're not launching hard.
Old Aug 1, 2003 | 02:47 PM
boomcase's Avatar
Does anyone think that the MAf and throttle body he has is hurting his time.
Old Aug 1, 2003 | 03:06 PM
BoomCase,
Why would you say that. Both MAF and BBK TB flow more than stock. By principle more air and fuel=more power or Am I wrong?
Old Aug 1, 2003 | 06:31 PM
42NightZ28's Avatar
Also reccomend the Yank SS3800 but i'm rather use to it now and it seems puny to me. a YPT 4200 maybe be what the doctor ordered for next year or at least a high stall on the current model.
Old Aug 1, 2003 | 08:01 PM
DreaD's Avatar
Sharkymark.. I have written a 3 page "essay" regarding my first ever TC install and my first impressions.. if you'd like I will be happy to send it to you. I hesitate to post it anywhere due to it's length. I'm sure, should you read it, that you will gain a better understanding of the entire process and how it works.
In general though I can't stress enough how much you will benefit from this mod. Keep in mind that there is an approximation equation that goes something like: every .10 subtracted from your 60' time will gain you 1.5 in ET reduction.
I was kinda scared to do the swap myself but i'm very glad I did. I've already dropped my ET's from 13.7 to 13.3 launching @1900rpm on DR's, a difference of 2.1 60' vs 1.9 60'. I feel very confident that I will be able to launch succesfully at 3100rpm or higher. Unfortunately the track got rained out and i couldn't run again for better times. I consider this to be extremely good considering the 3100' track elevation, DA and my limited mods (lid, catback & ST3500) I should be seeing 12's next test and tune night. I'd be happy to talk to you at length about the swap and other Q's you might have as I'm still very excited about the install - palin1@comcast.net
Old Aug 2, 2003 | 12:15 AM
Thanks DreaD,
I don't fear using one, I fear the expenses that might probably result from the added strain on the tranny. I only got 25K on the Z and it gets so hot in TX, especially in summer; sometimes over 100oF. Still though it is a "must" mod for any serious streetracer. I would like very much to read your report, if u want send it to AIECH69@hotmail.com.
