will not shift 1-2 @ WOT
Old Jul 31, 2003 | 07:58 PM
Stone0fFire's Avatar
Default will not shift 1-2 @ WOT
my trans has been taking longer and longer to get into gear when i go from R to 1st. it takes its time, and if i add throttle before it gets into gear, the rpms rise, nothing happens, and then i get a nasty clunk/kick. also, if im driving, and i come to a complete stop, esp quickly, the idle will drop to ~550rpm for a few seconds, then go back up to ~750rpm or so. sounds like its about to die out.
but most recently, i was doing a WOT run, and it hit the rev limiter and did not shift into 2nd until i let off the gas. i have a converter with me. should i hold off on installing it? should i wait until the transgo comes in? will the transgo fix this issue?
or will i need to rebuild soon?
Old Jul 31, 2003 | 08:11 PM
CRAZYCUBAN29's Avatar
Default Re: will not shift 1-2 @ WOT
rebuild not soon but now sounds like trans. is trashed. its trying to warn you
Old Jul 31, 2003 | 08:34 PM
what should i do?
Old Aug 1, 2003 | 05:08 PM
TA/30th 1002's Avatar
Would you be doing any work yourself? And how involved do you get?
That "dremeled MAF": Does that trick the PCM into thinking there is less load on the engine; and inturn increases ign timing, and decreases trans pump pressure?
... Ron
