TH350 conversion, need help
Old Mar 13, 2003 | 03:09 PM
twcamaro's Avatar
Default TH350 conversion, need help
My transmission place is going to use a 9" tailshaft, so I can use the stock DS. I currently have a BMR driveshaft loop. Will that fit with this setup? The next question is I want to use my current Random Technology Torque arm. Is it possible to fab up the current cross member to accomodate this? How difficult is it to get a speedometer sensor on the new transmission??
I've looked around, and found the Yank crossmember, but it was 395.00. I wanted to find an alternative. Thanks in advance.
<small>[ March 13, 2003, 03:59 PM: Message edited by: twcamaro ]</small>
Old Mar 18, 2003 | 12:32 AM
twcamaro's Avatar
Default Re: TH350 conversion, need help
ttt
Old Mar 18, 2003 | 12:39 AM
LS1x2's Avatar
Formerly 4mulaJoe
I don't know if the DS loop will fit. You would have to custom fabricate a mount to use that random tech tq arm or give your left nut for the Yank one. I would sell the tq arm and go with something that doesn't mount on the tailshaft.
