How "streetable" is a powerglide?
Old Apr 21, 2008 | 11:05 PM
brianatfum's Avatar
Default How "streetable" is a powerglide?
How many guys drive your LSX w/ a glide 100+ miles weekly? What stall do you use?
Thanks
Old Apr 21, 2008 | 11:11 PM
dlove's Avatar
https://ls1tech.com/forums/automatic-transmission/906839-another-1-circle-d.html
light weight car though. unless you are under 3k race weight dont consider it.
Old Apr 21, 2008 | 11:13 PM
brianatfum's Avatar
No, it wont be under 3k. Back seats will be removed but that's about it...
Old Apr 21, 2008 | 11:16 PM
dlove's Avatar
i would go with a th400 then.
Old Apr 22, 2008 | 12:13 AM
brianatfum's Avatar
Any other opinions appreciated.
Old Apr 22, 2008 | 08:28 AM
SVT THIS's Avatar
I'm curious to why the weight makes such a difference for a powerglide?
Old Apr 22, 2008 | 09:06 AM
Gilbert@Ace Racing's Avatar
The Powerglide shares the exact same high gear ratio as any 3 speed. It is a 1:1 ratio. Therefore it will be on the converter at road speeds. The Glide, as with many 3 speeds, does not have lock up and the converter will be trying to generate some heat during daily driving.
Powerglides were installed in countless millions of factory vehicles back in the day. Depending on the gear and the converter stall speed it may or may not be streetable.
It really is combination dependent.
g
Old Apr 22, 2008 | 09:07 AM
dlove's Avatar
the stock 1.82 or 1.76 ratio of first gear makes it very stress full on a tranny if the car is very heavy. Vs the first gear of say a 400 at 2.5, which makes all the difference. Also with a heavy car it will take a lot of HP to effectivly move the car out quick.
Old Apr 22, 2008 | 10:29 PM
whytryz28's Avatar
My 69 came with a powerglide and it ran great. Its weights in at around 3600.
Old Apr 22, 2008 | 10:37 PM
primer84z's Avatar
You'll probably want an OD at some point. Id go with the 400...
Old Apr 23, 2008 | 09:30 AM
dlove's Avatar
400 doesnt have on OD....
Old Apr 23, 2008 | 10:21 AM
badpanda's Avatar
Maybe he meant that he would have the option of a GVOD unit later down the road.
Old Apr 23, 2008 | 10:23 AM
382ssz28's Avatar
Let's put this into easy terms. The powerglide was a good trans back in the 60's and early 70's. The stall speed is very low at 900-1200 rpm. The cars were not that heavy. The reason weight is a factor is because of the stall speed. The heavier the car the more heat is generated from the slipping of the converter. You would also be taking off in 2nd gear essentially, (1.82-1.76 first gear ratio on PG). The 400 has a 2.48 first gear ratio, the 350 has 2.52, the 4L60 has 3.07. If you take off in 2nd gear with a high stall conv., you'll generate enough heat to melt the seals. Remember, the converter is a torque multiplier. It is basically 2 fans, one running the other through fluid coupling. The molecules being slammed around heat up very quickly which is the killer of trannys. It would not be an efficient trans for the daily driver. They are used in low weight, high HP race cars more as a tuning device. This is alot to explain so I'll stop right here. Hopefully this will help make your decision easier.
PS, your stall is based on alot of factors, starting with your cam specs @ .050" on your cam card. The converter companies will help you with this.
Old Apr 23, 2008 | 01:22 PM
primer84z's Avatar
Thats why I would go the 400 route.
Old Apr 23, 2008 | 01:59 PM
brianatfum's Avatar
More details on the GVOD unit please...
Old Apr 23, 2008 | 02:09 PM
primer84z's Avatar
www.gearvendors.com
Old Apr 26, 2008 | 08:45 PM
JUICED96Z's Avatar
https://ls1tech.com/forums/showthread.php?t=906839
Or have a lot of power to make up for it...
Need either power or less weight but like said above lots of cars back in the day came with them.
I would not use a glide if I drove my car a hundred miles a week. Just me though.
Old Apr 26, 2008 | 08:52 PM
b00sted's Avatar
Gear vendors offers one for a glide too.
