Moser 12-bolt Owners... install question
-3" u clamps for the sway bar bushings and just spread the stock clamsheel in a vice so the 3" u bolt will slide through
-some rubber hose for a vent line
-teflon tape for all the rear girdle bolts, fill plug, drain plug ( they will leak if not )
-correct u joint on Driveshaft
-3 quarts gear oil
-axle bearings may need to be pressed in ( depending if you opted for the backing plates )
You can drop the stock rear w/o disconnecting the brakelines. You may need an adj PHR to re-center the rear end
Justin
<small>[ March 17, 2003, 06:01 PM: Message edited by: Jsears8 ]</small>
ahh dont forget the primer & paint <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
