codes p0753 & p0300 Help!
Old Apr 28, 2008 | 07:16 PM
'91firebirdformula's Avatar
Default codes p0753 & p0300 Help!
I did a search on code p0753 and its the 1-2 shift solenoid valve performance. i'm also throwing a p0300 multiple engine missfire code. Im guessing that the engine missfire code is because of my 3600 stall. I'm heading to the dyno tomorrow to get a tune and that code was gonna get fixed, but now i'm not too sure what to do about the p0753. I got the codes deleted and it ran fine for a day. I pulled it out of the garage today and it was running like **** again. Do you think it's someting that can be fixed by a tune, since it drove fine after a day or is it the solenoid itself and i should cancel this dyno appt.? is it an easy fix?? Thanks!!
Old Apr 28, 2008 | 08:07 PM
tording99Z28's Avatar
I can say that the PO300 is probably from the converter like you said. You probably just need a CASE relearn to clear that right up. Happend to me when I did my converter.
Old Apr 28, 2008 | 08:13 PM
performabuilt's Avatar
LS1Tech Sponsor
Have your tuner remove the test for code po753 and -P0756 AND PO757 the code is likely a false code caused by the stall
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 28, 2008 | 08:21 PM
ok, great thanks! I have had the stall for over a year though. Does it sound right to finally start throwing it now? I really hope your right though. btw, i have had the lock and unlock problem with the stall since the install, too. Thanks for the input!
Old Apr 28, 2008 | 08:48 PM
LS1Tech Sponsor
The lock unlock will be from the missfire code
__________________
Call 888-744-6542
