need 4l60e Shiftkit info???
Old Apr 29, 2008 | 09:25 AM
TDPB2008's Avatar
Default need 4l60e Shiftkit info???
I have a 98 transam ls1 and i believe a 4l60e trans my next step is 3.73 gears and a shift kit but dont know too much about who makes the best kit and the best performing? and what kind of gains am i looking at in the 1/4. any info?
Old Apr 29, 2008 | 10:42 AM
EDS01SS's Avatar
You are gonna want to go with the Trans-Go shift kit. They make the best kit by far for the 4L60E. As far as better times in the 1/4 you will not see much of a gain with just a shift kit and gears.You would actually be better off with a 3500 rpm stall converter and the shift kit then you will be with gears.With the converter and shift kit combo your looking at around .5 seconds of your 1/4. With gears and shift kit you might see .2 off your 1/4 time.
Old Apr 29, 2008 | 11:12 AM
TDPB2008's Avatar
this is also a street car so could you combind the 3500 stall (would that be streetable) shift kit and the gear to gain the most.
Old Apr 29, 2008 | 03:40 PM
EDS01SS's Avatar
yes if you have the money and want the gear go for it. I ran my car with that combo for 5 years 19 miles each way back and forth to work everyday.3500 stall is very streetable in these cars.
Old May 1, 2008 | 12:17 PM
TDPB2008's Avatar
will my 10 bolt hold this or will i be breaking things??
Old May 1, 2008 | 03:45 PM
EDS01SS's Avatar
your 10 bolt should hold up just fine with an automatic and stock hp
Old May 3, 2008 | 10:33 AM
TDPB2008's Avatar
is anyone running this combo? and do you like it on the street. and do you need a bigger cam for the converter or will a stocker work? mine is stock
Old May 3, 2008 | 11:33 AM
deadcities's Avatar
Stock cam will work fine. Just get an auxiliary tranny cooler when you do the converter and you'll be fine.
Old May 3, 2008 | 12:46 PM
TDPB2008's Avatar
do have to do any tuning of the computer
