Shifter and flex plate recommendations?
Old Apr 29, 2008 | 02:01 PM
4SFEDZ's Avatar
Default Shifter and flex plate recommendations?
ok im comin over from the m6 world and need a shifter and flexplate for my th400! what do yall recomend?
Old Apr 29, 2008 | 08:16 PM
Firechikn's Avatar
I'm a rachet kind of guy. I just bolted in the b&m quick silver for my swap. It took some fabricating, but it's in and looks nice.
Old Apr 29, 2008 | 08:37 PM
theblur98ss's Avatar
cheetah shifter and tci flexplate. I had a b&m hammer and didn't care for it.
Old Apr 29, 2008 | 08:56 PM
4SFEDZ's Avatar
got any pics?
also i no nothing bout autos or shifters, but with a ratchet you can only change one gear at a time and it spring loaded, so i would be like hitting it once for rev, twice for neu, and three times for 1st and ect and dosent slide all the way thru like a stock shifter? that is if you tranny was park, rev, neu, 1st, 2nd, 3rd
Old Apr 29, 2008 | 08:57 PM
4SFEDZ's Avatar
and ive heard tci flexplates are the way to go!
Old May 1, 2008 | 06:48 AM
Firechikn's Avatar
Originally Posted by 4SFEDZ
got any pics?
You got it. It's a little pain in that aspect, but I like it when its go time. You just push the shifter up from 1st, it ratchets back, shift again. I've got the TCI flexplate as well.
Old May 1, 2008 | 09:52 AM
Stroked96Bowtie's Avatar
TCI and B&M Pro rachet here...really pleased with it. If you are using the M6 console guys just keep the boot and use it on the shifter. I went from an A4 and made it work with the stock console..turned out real nice. There are tons of pics on here of this setup.
Old May 1, 2008 | 02:34 PM
Firechikn's Avatar
I liked the pro ratchet too, with the **** and button set up. I could have used that for my 2 step. I just didn't know about the small lever on the side of the shifter. I couldn't tell if that was the lock out release or what. The pictures and descriptions weren't clear. Oh well. I guess now I know it could've worked. Guess I'll have to stick with my getto switch under my ****.
Old May 2, 2008 | 01:08 AM
DanZ28's Avatar
Cheetah here!
Some Pics of it Here https://ls1tech.com/forums/showthrea...0107&highlight=
Old May 2, 2008 | 10:47 AM
If is the lever on the left side, that sticks up next to the handle thats the lock out release. Keeps you from hitting neutral/reverse or really overshifting which can sometimes be easy to do with these shifters. Used a cutting wheel to mod the console to allow it to slide through it.
Old May 2, 2008 | 02:00 PM
QucikSilver's Avatar
I used a new GM flex plate and a Quarter Stick. The shifter fits perfectly in the A4 console where the old shifter sat. It looks very clean and you have the added advantage not havin to use a ratchet shifter. IMO. GM flexplate runs about $110.
Old May 2, 2008 | 02:36 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'm also running the TCI flexplate but I'm shifting gears with a Quarter Stick
Old May 2, 2008 | 08:53 PM
Firechikn's Avatar
couple of pic of my quicksilver and getto switch. you don't have a lever to pull to release the lockout, you pull the handle up.
