TH350 Dipstick
Old May 1, 2008 | 09:35 AM
Stroked96Bowtie's Avatar
Default TH350 Dipstick
Ive got a deep pan dip stick in a Th350 that doesnt have a deep pan(minor oversight during purchase).
Is there a way to be sure there is enough fluid in it without looking at the dipstick? Can I just replace the dipstick without having to replace the dipstick housing?
Old May 2, 2008 | 01:11 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I would think the tubes would be the same
DanZ28's Avatar
I thought the dip stick stayed the same length regardless of deep pan or not, it just holds more lube?
Old May 2, 2008 | 10:44 AM
Really? Can anyone confirm this for us? I was thinking because it was made for a deep pan it would be made longer.
Know theres some trans shop guys around here
Old May 2, 2008 | 01:14 PM
DanZ28's Avatar
I'd like to see them chime in because I'm using a deep pan and I found no dip stick made specifically for it, just a regular one. You want your level to stay the same with a deep pan, there is just more lube in the pan is all.
Old May 2, 2008 | 01:56 PM
QucikSilver's Avatar
There is not going to be any difference in the length of the dipstick. If it is a stock pan Th-350 it should have about 7 quarts of fluid in it including the converter. Deep pans hold about 8 quarts if that helps any.
Old May 3, 2008 | 10:43 AM
Thanks guys...that does help. Makes me think Ive got too much in there now I filled up passed the marks thinking this stick was too long. Seems to shift and run good, not puking any fluid so I guess I will just leave it there.
Old May 3, 2008 | 04:03 PM
DanZ28's Avatar
If it really is to full, I would fix it. How many total quarts did you put in?
Old May 6, 2008 | 01:14 PM
I'll double check it today, its hard to say because as I was putting fluid in it the first time, I forgot to put the kick down cable in and it dumped probably most of what I put in it seemed (huge mess on the garage floor). From there I added probably another 4 qts. I might be a quart high, but when I get home I will take it around the block and see where its at.
Old May 7, 2008 | 05:34 PM
382ssz28's Avatar
The length on the inside of the trans is always the same. The length of the tube and stick on the outside can drastically vary, meaning no matter how long the stick and tube assemblies are as a matched set, they will always register properly. Our shop uses the BTE locking dipstick and gold irrited tube with the boot seal. Perfectly acurate and no leaks. Part # 323850, for your knowledge.
PS, Quicksilver, a stock 350 with converter holds 10.25 quarts-deep pan about 12 quarts. 13+ with a cooler. 11.5-12.5 with 3500-4000 stall and cooler, for your knowledge.
Old May 7, 2008 | 06:58 PM
DanZ28's Avatar
Good info! Will the dipstick fit in our f-bodies?
