Important 4L80 cooler fitting info
Old May 2, 2008 | 09:53 PM
TOOSLO5's Avatar
Default Important 4L80 cooler fitting info
Posted this in the conversion area since it seems to come up often. Hope it can help someone out here also.
https://ls1tech.com/forums/showthrea...55#post9287155
Old May 3, 2008 | 09:14 PM
9000th01ss's Avatar
It's in the sticky here somewhere, the pic posted was taken by me.
Old Feb 27, 2009 | 05:19 PM
slow67's Avatar
Gingervitis Addict
Bringing back an old thread. Found a better way than ordering the expensive Sonnax kit (for those going with AN Lines)
46340A from transmission parts use dot com. It is the long special fitting, made for 3/8 inverted tube. Then you need a -6 to 5/8-18 Inverted Flare, such as Earl's 991947ERL.
Old Feb 27, 2009 | 06:54 PM
forcd ind's Avatar
i screwed the rear fitting in, marked it to point to the front, then ground it down a little, tig'ed a 90 deg steel AN fitting-no room for anything else
then used an ATI Perf #6 AN to 1/4-18 STRAIGHT fitting in the front
Old Mar 8, 2009 | 04:05 PM
trey04gto's Avatar
Can you just buy 2 of each of these and they will both work with modification?
Old Mar 8, 2009 | 10:57 PM
trey04gto's Avatar
Anything here..
Old Mar 8, 2009 | 11:05 PM
slow67's Avatar
Gingervitis Addict
No, only the rear fitting is special. The front you can just use a 1/4 npt fitting.
Old Mar 12, 2009 | 02:36 AM
trey04gto's Avatar
On the -6 to 5/8-18 inverted flare, Did you mean 3/8-18 inverted flare?? I just ordered the 5/8 and now im thinking its wrong...
Old Mar 12, 2009 | 08:52 AM
slow67's Avatar
Gingervitis Addict
Nope, I thought that too. 3/8 Inverted flare nuts use a 5/8-18 thread size, as 3/8 is the steel tube size. I ordered 1/2-20 at first and it was too small.
Edit: Shown by this link, as well as others (ONLY to show 3/8 tube nut threads)
http://www.fmsiinc.com/brake-line-fittings.htm
Old Mar 12, 2009 | 09:05 AM
9000th01ss's Avatar
Thats not a 1/4" NPT
I guess you could take a 1/4" NPT, goop it up, and drive it home.
The correct fitting is metric. 12mm x something.
Old Mar 12, 2009 | 09:25 AM
slow67's Avatar
Gingervitis Addict
http://www.tciauto.com/Products/Tech...r_fittings.asp
TCI says it is. Actually it is the same threads as a pipe thread, just meant not to have a taper and use an O-ring. 1/4 npt works just fine. Just don't overtorque it and crack the case.
Old Mar 12, 2009 | 10:59 AM
9000th01ss's Avatar
You're right, I just looked at one.
