whats wrong
Old May 6, 2008 | 12:21 AM
neals98's Avatar
Default whats wrong
What if you just changed to a th350 and the first 4 or 5 runs it done great. then change to another stall ran it 3 times and on the fourth pass i stalled up at the line and when i left it just boged down untill about the 60ft mark and then takes off like i shot it with nitrous.........It will not even do a burn out now....... It has a trans brake and a vig stall..Do you have any ideas what it might be......trans,converter or .........I have it on my trailer now and i can put it in first and try to power brake it the rpms will go up to about 3000 but that is it and the tires will not turn over.......
Old May 6, 2008 | 09:35 AM
neals98's Avatar
ttt..anyone
Old May 6, 2008 | 04:04 PM
neals98's Avatar
I found out today...I put my old converter back in and everything works great....It was the vig converter has anyone else had this problem.....
