700R4 keep it or scrap it???
Old May 7, 2008 | 02:30 PM
nuckingfutzz's Avatar
Default 700R4 keep it or scrap it???
I have a 85 T/A that had a 305 TPI in it. I am now dropping in a 355ci and I took all the computer junk out off it. I plan on using this car as a daily driver with some visits to the track. Also the 700R4 tranny I am going to use is stock and has sat for about a year now. BTW I need overdrive I
My questions are, should I be concerned about the reliability with a more powerful engine? Would a rebuild be helpful? Will I still have O/D without the computer? Should I just go with a new tranny?
I am on a budget right now but any input would be greatly appreciated. Thanks.
Old May 7, 2008 | 02:35 PM
performabuilt's Avatar
LS1Tech Sponsor
Well the trans probably could use a going through, It will have overdrive but without the wires it will not have lockup and may over heat. You make want to consider a lockup kit for the 700r4 like TCI sells. Personally with and 85 I would consider replacing the unit with a built one . More than likely with the new engine you will be anyway.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 7, 2008 | 03:08 PM
Would a tranny cooler help??? Could I get away with a stock rebuild? How much abuse can this transmissions take, if I could get it to last the summer thats all I need. A new trans was planned for next year when I do the rear-end and add some N2O.
Old May 7, 2008 | 04:23 PM
LS1Tech Sponsor
You could put a mild shift kit in and a cooler always helps But wether it will last till next year to many variables I am afraid to make a call depends alot on how hard your drive it
__________________
Call 888-744-6542
