How Does This Fluid Look?
Old May 6, 2008 | 11:24 AM
vMaster0fPuppets's Avatar
Default How Does This Fluid Look?
I've been having a problem with my Performabuilt trans shifting hard lately. The trans is less than 2 years old, and the fluid was drained and filled about three months ago. This is what I drained today. I see a little bit of black stuff floating about, but nothing settled at the bottem of the pan. I don't know how to read fluid. :shrug:
How does this fluid look? I had to stir it for the stuff to show in the pics.
Thanks in advance.
Old May 6, 2008 | 11:33 AM
staringback05's Avatar
HOLY **** turn your head to the left and theres a face in the middle picture
how does it smell?
and you might want to resize your pics or add them as attachments
Old May 6, 2008 | 11:36 AM
I'll do something. I've never had them come out so big.
Old May 6, 2008 | 11:40 AM
performabuilt's Avatar
LS1Tech Sponsor
BIG PICTURES!
BUT though its hard to see much in a black pan I don't see anything I would be worried about from what I can see. Hard shifts can come from several things, 1 have you had the car scanned? The most likely trans related possibility would be the PCS (pressure control solenoid) since you have the pan off I would change that its the largest solenoid.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 6, 2008 | 11:42 AM
Luder[PAK9]'s Avatar
how does it smell?
Picasso?
Old May 6, 2008 | 11:48 AM
I couldn't make the picture smaller, so I got rid of most of them. I'm glad you say that it doesn't look like there much to worry about.
It seems like draining the fluid fixed the problem. It looked overfilled beforehand, so I paid more attention when refilling. I'll know for sure in a couple of days.
I plan to get it really flushed pretty soon anyway. What fluid does Performabuilt recommend put in their transmissions?
I don't have any codes currently. I had one pop up a while ago, but it went away within a couple of days and hasn't come back in weeks.
Old May 6, 2008 | 11:50 AM
LS1Tech Sponsor
We have no recommendation other than it meets or exceeds dexron/mercron requirements users choice.
__________________
Call 888-744-6542
Old May 6, 2008 | 12:33 PM
382ssz28's Avatar
Before you mention who's trans this is, you should pm with pictures to the people you bought it from and ask if things are good from them. If not satified, then post your pics on a site for questions from others. Just an opinion.
Old May 6, 2008 | 11:29 PM
I'm not saying anything about the compony. I just don't know how to tell if the fluid looks good. I also know performabuilt is on her regularly, so I was expecting a reply from him.
Old May 7, 2008 | 01:17 AM
daniel6718's Avatar
on a side note when you pull the pan and replace filter and reinstall how much fluid should it take?
i read 5 qts so i drianed my pan...pulled the filter let the car sit for an hour and drain...drained my lines and tranny cooler...put it back together and added 4.5 qts and the stick says im way over full? wtf? is the ls1 and lt1 dipstick tube differant from a 94-99
Old May 7, 2008 | 09:06 AM
LS1Tech Sponsor
Are you checking the fluid with the car running ?
__________________
Call 888-744-6542
Old May 7, 2008 | 01:21 PM
9000th01ss's Avatar
Your fluid should look like the new fluid but maybe darker.
That fluid looks like it has fine metal in it because it's not uniform in color.
Old May 7, 2008 | 04:40 PM
daniel6718's Avatar
performa built i made a new thread...and no i wasnt...ill go do that rear quick
