AOD any one using them on their LS1???
Whats up fellas,I was wondering if anyone has used FB performance's 4STB??It's a Ford AOD trans thats all beefed up fully equipped with trans brake-variable stall controll-V.S.C. and a wide band gear ratio??I havent finished the project yet but was wondering if anyone has had good results with this setup...
Re: AOD any one using them on their LS1???
Ford transmissions are junk. Like Marc said, Mudstain guys go to all lengths to put GM tranny's in their cars for a reason
We have a dozen work vans all with AOD trannys and you can have them all. Our Fords are down all the time with blown trannys while the GMC's keep on going.
