Poll: 4L60E, How Much is Too Much?
So my question is, at what point does everybody feel that a 4L60, no matter how built, is just not enough? 300hp? 400hp? 600hp? Any FI or nirous car? Sub 12, 11, or 10 seconds?
I know there will be many answers, as with everything some have had better luck than others. But there has to be a level where there is just no point in trying it.
After I did the cam etc. the stock trans did not live long. I had a complete race/HD rebuild done by Mike Kurtz in 1998 and that lived until about 10 days ago. That was in a car with 350 RWHP/365 RWTQ and for 25K miles and 300 passes at the track and ~100 on the street.
Now I have "the best" available rebuild using some parts that were not even available back in '98, so the tranny is stronger than it ever has been. I will be spraying a 100 shot on it and it "should" hold. However, my builder said that if I want to go any higher, a turbo 400 should be in my future.
I can let you know later how it holds ~450-475 RWHP street racing. I will be running motor only at the track as I don't have a cage.
I knew this would be very subjective to what everyone feels is an "acceptable" lifespan. 10k miles, 20k miles, etc. Personally if I can get 20-25k from a trans before a rebuild I'm happy. But there comes a limit where no amount of aftermarket can get a 4L60 to that level, and I'm interested in finding where that level is.
Pete, you know how much I've raced my car. I now have 12,000 miles on my car. I would say about 6,000 of that was every day/drag racing miles the rest of it is pretty much all drag racing driving. My tranny started to feel mushy before the big vert when in. Then after the Vig 4400 went in and 17 hard launches at 2,000 my stock tranny gave way. All that before it hit the 12,000 mark... very high up in the 11,000 range for miles.
That's about how long my last stock rebuild lasted, well actually 16k with MANY bottles of juice, plus the fact that I beat the ever living snot out of my car every day I am in it. What I'm really after here is what can be expected from a seriously built up 4L60 in the long term
Since I have my trans sitting in peices on my workbench right now, it's time for me to start doing some planning. As of right now I'm sidelining my car till spring.....
..... and that's all I'm going to say
Just let me know what day your racing so we can both get new best ETs. You know how our luck runs. You get a new best I get a new best
For the rebuild I’m putting in blues and steels, a larger sun shell… deep pan, super servo’s “billet” But really the Trans was in good shape after 61k. My over drive steels had some diss color from heat. I mean they can’t last forever but I think with regular fluid changes it will have a longer life. Keep the thing from slipping
I know this might not be the best way to find out the weak points but when you tear a part up replace it with stronger after market. That’s if you don’t mind pulling the Trans all the time…
i killed my built tranny with a stock 6.0.
oh yea, 9psi and a 100shot too with 4wd launches in a heavy truck. had to be close to 600rwhp before it let go.
i had alot of 8psi and 75shot passes, probably 50 or more. no dyno numbers but i am prety sure that is over 500rwhp.
http://www.fbodytrans.com/index.html#transmissions
I let you know when I get it in, just wait for a fresh convert.
Impala running their level 3 tranny
