driveshaft length with th400 swap
Old May 17, 2008 | 04:14 PM
1fast97gsx's Avatar
Default driveshaft length with th400 swap
I'm waiting for my th400 and all the swap parts, but I can't really meassure the driveshaft while I'm waiting and I need the car up and running asap since it's a daily driver. Can someone give me their measurement so I can order it in that length? It's a speed inc th400 with stock rear.
Old May 17, 2008 | 05:50 PM
ls1fst98's Avatar
stock height? i did mine but i dont recall the length...i can get under the car and measure for you if thatll help...
Old May 17, 2008 | 07:39 PM
98turbls1's Avatar
mine is a d inch tailshaft and mine is 44 inches if i remember correctly...
Old May 17, 2008 | 08:02 PM
ls1fst98's Avatar
mine was in that range...like 43 and change
Old May 17, 2008 | 09:46 PM
1fast97gsx's Avatar
Yea it's stock height, stock rear. I'd appreciate if anyone can give me a 100% sure number just in case. Thanks.
Old May 23, 2008 | 12:04 AM
1fast97gsx's Avatar
Hopefully someone will stumble across this soon ... I'll be getting the trans in a few days.
Old May 23, 2008 | 02:37 PM
pddye's Avatar
I just put mine in about a month ago and Eric from midwest chasis got me the driveshaft from strange. Message him and maybe he remember what the legnth was and even get you a good price on the shaft.
Old May 24, 2008 | 01:02 AM
1fast97gsx's Avatar
pm sent to pddye
Old May 24, 2008 | 01:33 AM
nwforever's Avatar
i was actually wondering this myself. i am going to swap in a th400 short tail and i have the stock 10 bolt
Old May 24, 2008 | 08:45 AM
pddye's Avatar
pm replied. My trans is a short tail which I believe is a 4" and a 12 bolt but the 12 bolt still uses the stock style u-joint in the same placement. So it should work just fine for ya. I also I think if you let eric know on a monday he can have it to his shop on that friday if strange can get your order made.
Old Jun 24, 2008 | 11:11 AM
oldschoolmuscle's Avatar
bump i was wondering the same thing, i am running outa time quickly was wondering if someone knew the length for a short tail shaft to a 10 bolt stock ride height.
Old Jun 24, 2008 | 12:29 PM
pddye's Avatar
Just pm Eric at midwest chasis. He got my strange CM shaft for me like I said previous.
Old Dec 15, 2008 | 02:56 PM
Dirty 30's Avatar
what was the length after all?
