Need some newbie help on transcooler
The initial thought was that the air that comes up the air dam gets to the top of that shroud (where my cooler is) and has nowhere to go but through the cooler, cond and radiator. I even lowered the low speed fan settings so air would constantly be pulled through it.
The highest temp I've logged was 165*
The problem is my lower airbox and shroud was cut out so the bottom of the air filter would be exposed to this air coming up the air dam. When I put a/c and shrouds back in the car all that got blocked, if I go to cut it out again the heat from that cooler is going into the air intake.
I've also recently logged IAT's at 126* and it doesn't come down right away like it did with the shrouds and cooler not there.
Now don't tell me...you got mounting figured out you need info on running it in series
