cooler lines
Old May 18, 2008 | 09:47 AM
saylorZ28's Avatar
Default cooler lines
has anyone use steel braided an lines for there tranny cooler if so what size fittings to fit in tranny
Old May 18, 2008 | 11:10 AM
FLT's Avatar
FLT
1/4 pipe to -6 male AN fitting is the ones you want to use. Be careful when installing these. Reason is that the fitting will not fully bottom out on the transmission when you tighten it down like tradition fittings. The thread pattern will work just fine with a bit of Teflon PASTE applied to the threads. I do not care for the tape for this application. Make sure that the fitting is good and snug when you tighten it down. Just make sure not to be an animal when installing these or you will break a case. Vince
Old May 18, 2008 | 04:28 PM
saylorZ28's Avatar
i didnt know if it would be fesable .... i was wantin something functional and that looked good
Old May 18, 2008 | 04:48 PM
curtisad's Avatar
It is under the car....who is going to look at it?
Old May 18, 2008 | 06:35 PM
saylorZ28's Avatar
not that any one will see it but it is the fact i know it looks good .. plus the added fact if anyone does it will lmmao
