What Tools Are Need
Old May 18, 2008 | 08:25 PM
deputyss's Avatar
Default What Tools Are Need
00 Ss Camaro Converter Swap. What Tools Will Be Needed. I Just Went To A Vig 3200. Thanks Guys
Old May 18, 2008 | 09:44 PM
dpinson's Avatar
3 feet or more of extensions and a swivel 3/8 drive to undo tranny
13mm for the tranny bolts
the torque converter to flexplate bolts are different on some cars but 16mm is what i know
13 mm for the starter
not sure on the rest but they are all pretty common tools if you have a good set
and it is easier to use a 15/16 socket on the crank pulley to turn the motor so you can get to the three bolts holding the converter
Old May 18, 2008 | 09:47 PM
dpinson's Avatar
auto zone sells a 2ft long 3/8 extension and you might need a 1/2 inch to 3/8 adapter so you can get a little more leverage
Old May 18, 2008 | 09:59 PM
deputyss's Avatar
hey thanks man.
Old May 19, 2008 | 12:12 AM
9000th01ss's Avatar
8MM allen head on a 2000 year converter bolt--no hex. If it had a hex head it would be 15mm.
A 10mm socket and something to remove the O2 sensors with as well, better remove them to not risk damaging one.
