3rd and 4th clutches
We rarely sell individual components and/or overhaul packages.
Good Luck!
g
Don't use a kevlar band imo they're too hard. Do use a wide band. Also do use one with a reenforced lug. So you can use big billet 2 and 4 servos and eliminate the 3rd accumulator. Alot of shops wont spend the money here, or they consider the corvette is good enough. Its just something I like to do and it has eliminated band failure for me.
The places you're going to run into trouble on your own is with the bushings, imo they should be changed every time. Also resizing the teflon sealing rings on the pump and input drum are difficult for new builders without propper tools.Tight tolorences are the mark of a good trans build. Set your 3-4 pack tight on clearance, throw the load release springs away, or buy the transgo tougher ones. I like to just throw them away. The stock stuff is only good for stock clutches.
Also i cant seem to get photo bucket to down load/ HTML my pics.. Is there some other way to post them up... This thread is worthless with out pics
http://www.performabuilt.com/dumontpics.html
dropped tranny off at shop this morning...
tear down revealed burnt up 3-4 clutches, band and warped reverse drum...
thorough inspection and rebuild starting tomorrow...
