No reverse (fresh build)
Old May 20, 2008 | 02:55 AM
01WS6/tamu's Avatar
Default No reverse (fresh build)
I built this 4l60 for my s10 with ls swap last year about this time. It has all the goodies and I put oil in the pan before putting it in and a quart in the converter. It has all of the forward gears but has no reverse you cant even feel a slight bump like it even want to try. Step on the gas and it will rev but go nowhere. Does it sound like a may have cut a seal when I put it back together or something?
Old May 20, 2008 | 07:06 AM
performabuilt2's Avatar
LS1Tech Sponsor
check the reverse boost valve in the pump gthe snap ring may have not seated
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old May 20, 2008 | 08:34 AM
performabuilt's Avatar
LS1Tech Sponsor
Theres a small metal plate at the rear of the VALVE body under the solenoids with three 8mm bolts is it there did you tighten those bolts?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 20, 2008 | 09:12 AM
01WS6/tamu's Avatar
I'll check those few small things this evening after work. ...........to be continued.
Old May 24, 2008 | 12:26 AM
01WS6/tamu's Avatar
Found it I somehow cut one of the teflon rings on the bottom of the oil pump when I installed it. Moral of the story do not overhaul a trans at 2 am in the morning after a long day of working on other peoples junk *** cars.
Old May 24, 2008 | 12:45 AM
LS1Tech Sponsor
How many beers lol
__________________
Call 888-744-6542
Old May 24, 2008 | 05:53 PM
LS1Tech Sponsor
those seals are easy to cut when installing the pump I have done it myself. I have found that myself after sizing them take a new reverse input drum bushing and put over the seal for a few minutes makes them a little tighter and they go in alot better
__________________
Old May 25, 2008 | 12:54 AM
01WS6/tamu's Avatar
I haven't though of doing it that way I'll have to give it a shot that way. I overhaul very few except for a a few select customers. These days I love gm's warranty on their SRTA trans' and if it dies due to abuse it's on the generals back. I try to only do performance builds here and there and our old customers who I know who won't tear it up and bring it back on a hook. Thanks a million for the the help.
