mileage
Old May 20, 2008 | 08:24 PM
Default mileage
what sends the signal for the odometer to turn? i have a 96 Formula i just bought from an individual and the odometer is not working. it is a 4L60E.
TIA
Old May 20, 2008 | 08:28 PM
performabuilt's Avatar
LS1Tech Sponsor
VSS same sensor that makes the speed o work if the speedo works but the odometer does not the problem is likely in the speedo cluster
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 20, 2008 | 08:45 PM
cool, the speedometer works, but the odometer does not turn. i will take a look at it tomorrow after work. thank you very much.
