Anchor Brand Trans Mount
Old May 29, 2008 | 08:25 PM
Slowmaro305's Avatar
Default Anchor Brand Trans Mount
Ok so i just replaced my trans mount with a regular rubber one by Anchor part number 2817. Everything bolted up fine except the screw that comes out of the rubber mount and through the cross member is smaller on the anchor mount. Any one have experience with this before? If this is common does anyone know what size nut will fit this mount so i can bolt it to the cross member?
Old May 29, 2008 | 08:31 PM
9000th01ss's Avatar
I've had that happen, the nut you need is metric, 10mm coarse thread I think. It's the same size as the bolt that holds it on the trans so you could pull one of those out and take it somewhere to match it up.
Old May 29, 2008 | 09:46 PM
FLT's Avatar
FLT
I believe the stud is a M10x1.5.
Old May 30, 2008 | 08:15 AM
Thanks for the responses. Even though its not a big job, i am trying to not take the mount back out to bring to the store and check lol.
