help! trans will not shift
Old May 30, 2008 | 10:30 PM
35thz28camaro's Avatar
Default help! trans will not shift
i just up graded my stall from a 3600 to a 4000, now my speedometer will not work and my trans will not shift! i have checked the big conn on the side of the trans and the small one on the tail shaft about 3 times. and i check all the fuses. need help asap, please!
Old May 30, 2008 | 10:43 PM
performabuilt's Avatar
LS1Tech Sponsor
First thing is figure out the speedo check the wires and the connection's at the VSS this is why it wont shift no VSS no shift.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 30, 2008 | 10:44 PM
lol sorry but what is the vss
Old May 30, 2008 | 10:45 PM
LS1Tech Sponsor
vehicle speed sensor it in the trans tail housing has two wires going to it
__________________
Call 888-744-6542
Old May 30, 2008 | 10:53 PM
its pluged in and the wires look ok, how would i check the sig, should it have power?
Old May 31, 2008 | 12:25 AM
LS1Tech Sponsor
If you dont have speedo working you have either damaged the wires or the sensor
__________________
Call 888-744-6542
Old May 31, 2008 | 05:46 PM
it was the vss sensor! thanks!
Old May 31, 2008 | 06:04 PM
LS1Tech Sponsor
Your allways welcome
__________________
Call 888-744-6542
