wtf is going on
Old May 31, 2008 | 12:36 PM
TX RED's Avatar
Default wtf is going on
OK so i took the new trans and Tc to see the car would run the trans shifts great it pull real nice. One problem and probably not tranny related but i will let the videos do the typing
see how as soon as the body lifts the car truns off all the litte lights come on in the dash. i dont thin it fuel i had half a tank
Old May 31, 2008 | 12:39 PM
FLT's Avatar
FLT
Check your grounds. Looks like you are loosing the BAT. power when it launches if I had to guess. Vince
Old May 31, 2008 | 12:45 PM
TX RED's Avatar
bat ground... i need to get under the car and check it out
Old May 31, 2008 | 12:47 PM
SuperSport01LS6's Avatar
I 2nd that ^
Old May 31, 2008 | 12:50 PM
your battery might be moving and contacting the body and shorting out for a sec. also check the tie down make sure the battery is secure. that shock is def. shutting the system down. for sure power/ground related check your fuse box positive terminal connections as well
Old May 31, 2008 | 01:03 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes you are definatly either loosing connection or shorting to ground during the launch, Check all battery cables and grounds and do not drive until you figure it out a pos ground to the chassis can result in a fire quickly!
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 31, 2008 | 01:28 PM
TX RED's Avatar
i think i found it the batt brkt is broken and there are marks on the ac dehydrator thats the little aluminum canister for the ac
Old May 31, 2008 | 01:39 PM
LS1Tech Sponsor
Sounds like you found it and minimal damage good
__________________
Call 888-744-6542
Old May 31, 2008 | 01:45 PM
TX RED's Avatar
i was still running 12.7 12.6 all night lol
Old May 31, 2008 | 01:52 PM
sslateron's Avatar
You need a new transmission. jk
Old May 31, 2008 | 02:01 PM
TX RED's Avatar
........lol
Old May 31, 2008 | 02:49 PM
FLT's Avatar
FLT
+1 and a new battery hold down comes free with it! Good to hear you got it! Vince
Old Jun 1, 2008 | 05:42 PM
my number 1 hater's Avatar
The battery hold downs are known to crap out.. And let the battery slide back under hard launch....
